Sean Krupa
Moderator
What is the difference between a Syty and a regular 4.3 Engine block?
syty blocks have nodular main caps is what my machine shop told me.
yes, those are the caps, not the block though.syty blocks have nodular main caps is what my machine shop told me.
Thanks guys. Let me rephrase this, what is specific to a Syty engine compared to a regular 4.3 (Internally)?
I'll need to know this information for my Engine rebuilding class at school.
Thanks,
you can use any normal (pre 1996) 4.3L engine block to start as a foundation for a build. Just make note that the mid-80's (specifically 1985) have a 2 piece rear main seal. There may be other slight variations, but thats the only significant one.But if you go to the 4-bolt, then that is moot correct?
I want to buy a non-vortec, external balance 4.3 and build it. Are those the only things we need?
May be a dumb question (and a lil off topic due that it's not "internal"), but...
Do regular 4.3 blocks have the holes for the turbo oil feed/return? And the return hole for the coolant?
Do any other 4.3 vehicles utilize those two holes?
Maybe a little off topic, but would a later model 4.3 be better to rebuild than a syty original engine?
How about knock sensor hole? Syty specific or do all non balance shaft blocks have it in the same location?
I think Dave's beating a dead horse smiley will come in use here
:horse:
THERE IS NOTHING SPECIAL OR SYTY SPECIFIC ABOUT THE BLOCKS! PERIOD! NO SPECIAL HOLES! THEY DIDN'T CAST SPECIAL BLOCKS FOR OUR TRUCKS!
Why are you yelling at me? For the record I didn't claim syty specific block maybe just set up or prep.
I just realized I don't care. lol but thanks for the info.:tup:
