Black Knight
I Glow Therefore I am
Re: Syclone 934 Restoration
Wow, you've got a lot of gorgeous pieces here, work of art.
My guess is you work at a machine shop? Are the aluminum motor mounts 2-piece bolt together, or machined out of a solid chunk of aluminum? They are very nice. Can't wait to see what else you have in store.
Yes I own a machine shop with my brother, K&J Precision. I am also a certified TIG welder.
The upper mount is 1 piece billet 6061 T-6 Aluminum with nitronic 60 SS inserts for the bolt. The frame pads are 1 piece billet 4130 steel.
Next up I am going to make billet aluminum valve covers, sometime next month.
In the meantime I am porting the exhaust manifolds, welding and porting the upper intake and getting all the pulley brackets cleaned and painted.
Get all this done then the motor will be ready to put in the frame and then its on to putting the 4L80E in.
Everything looks great. Keep up the good work. When you put the 4L80E in will you be machining your own shaft and adaptor plate?
Nick
