clone 94
Re: stock crank limit
i cant speak for Tim but i ran a very small amount of meth. my 50# inj. were at 90%dc at 25 psi and 5k rpm. i had plans to tune for much more meth to lessen the load on my injectors but then i decided to pull the motor for something a bit more serious
the pt61 uses the gt35 compressor wheel, 61mm inducer. there are compressor maps all over for that wheel. pt61 only indicates the comp wheel size. my turbo was the 6152e, garret t-350 exh wheel and an e compressor cover (3 in 2 out).
its a decent sized turbo, has pushed some GN's into the 10's
how much meth were you spraying? we have 60lbhr injectors which flow more like 72ish lbhr with our fuel pressure. with 13psi we are at 85% duty cycle. how big is that pte61? the way this thing runs with 13psi i would be scared at 20+psi.
