Six-is-Enough
Use to do a little Boost
Re: Some cage pics
i'd say closer toa 5.0 L.:lol:
now that i don't believe. gotta be a bit bigger w/ your bore/heads. :lol:
You better bust out the chromoly tubing and the tig welder brother!:tup:You need to be careful with the weight comments. My truck has a sever complex when it comes to its weight and is currently doing everything possible to shed a few pounds.
I hope you are not wanting to pass tech or get the cage certified. Because our Trucks have a frame (vs Unibody) we are required to have the mounting points pass through the body and be welded to the frame. The pics look as if you have the mounting points welded to floor plates.
John
No, the plates cover where the tubing goes through the floor and to the frame.
Everything was done to make sure tech and certification was not a problem.
Only question I have, which maybe you can answer, is does the seat have to mount to the bar behind it? Or is that a certain ET range?
The certified sticker on the roll cage certifies the cage. The seats and all the other track stuff is a track tech issue. The seat mounts fall into the track tech and it just depends on how picky they are at tech. I have run expired seat harness and no tech has ever even looked at them. Same thing goes with most of the safety rules. Most of the SFI required parts are never even looked at, but technically may be expired or not even installed.
John
Mike doesn't like me pushing him to do all the sfi stuff and to follow the tech
