shift point question
if i want to raise the shift points from the stock 4400 or so from factory to 5000 or higher how do you go about doing this.
i am speaking about WOT shift points do you adjust tv cable as i thought this was for part throttle?
or is it done thru a chip
bdydrpds10
Yes I drive a Typhoon.
Re: shift point question
im trying to lower mine at the moment and I think the problem with mine is the governor. My transmission was replaced somewhere along the line and I do not have the stock Syclone governor. THe stock governor should shift about 4400. All other 700r4s had different governors that shifted higher.
I think I have ~5000 RPM Govenor, but I would have to find it. You can also buy a B&M Govenor kit and play with the weights and springs.
