Russell Fittings for turbo oil/water lines
John C Holmes
Do they make any for our stock turbo lines. I bought some new oil and water lines and would also like to replace fittings. Sizes and or pn would be nice. I'm talking about the oil connector on top and far passenger side of turbo.
Thanks
Cody
<font size=-1>[ This Message was edited by: John C Holmes on 2002-03-14 14:42 ]</font>
V6 Kompressor
I just bought a new turbo oil supply line from gm for $50 and a new ic to throttle body hose for $23. I was going to do the earls route or the Parker hyd. hose store and have one made up, but you can still get em from the general... I don't have an earl's catalog, but I will get an aeroquip catalog tommorow and see what kind of fittings will work, part numbers ect. In being the turbo is mitsubishi, I suspect the fitting on that end is metric.. I will look at that this weekend and email ya, unless someone already has went this route and knows numbers ect....
SyTyJedi
Jedi Council
Get the oil feed line from AR Autosports that feeds from the oil filter. Mike - you got a price on that? Much cleaner looking, cleaner oil for the turbo, and gets rid of that stock line running laps around the motor before it gets to it's destination. Need to block it off at the oil pan...I'm sure Mike has a plug for that too. :grin:
V6 Kompressor
Where does the oil drain to, if you are pluging the oil drain on the pan? :smile:
ghettosled
SYTY SUPERSTORE
i havent sold any of those oil feed lines, basically b/c i have never been approached to. Its pretty simple, and if interested i could work up a price.
SyTyJedi
Jedi Council
The turbo gets its feed from the pan, so it's not really that clean. The drain goes back to the pan on the passenger side. You would need to block the feed on the drivers side of the pan where it feeds the stock turbo.
