warmpancakes said:its 4 inches wider than a stock 4x4 and 8 inches wider than a stock 2wd
If I had any money Ild probably send you a reward :lol: Seriously though, thanks for the info. I measured mine last night at 59" from drum surface. So if 62" is the ZR2 then I coudl use that with my Z06 wheels and not have to run a spacer anymore and it SHOULD look normal? I have 1" spacers so hopefully a 1/2" wont be ridiculous. If so, I guess I could look at it as a good excuse to do Geiger style cladding :lol: Reason why I was bent on with or without rotor is because you dont mount your wheels on the hub, you mount it to the rotor, well over the rotor you know what I mean IM sure.mattw said:98 and newer rears come with disc brakes
these rears are 3.9" wider than a normal 4x4 rear
2WD Rear 54-3/8"
4x4 Rear 58-3/8"
ZR2 62-3/8"
warmpancakes said:to use the zr2 you need to either
1 change fron ratio to 3:73
2 charge rear ring and pinon, and carrier or get the thicker 3:42 ring gear
