I'm using a set of crane, self aligning, 1.6 ratio for 3/8 studs. I also replaced the metric studs with small block chevy studs. The stock steel valve cover is supposed to work with these, but I haven't put the heads on yet.... the vortec heads use a 10MM metric sized, non adjustable, screw in stud. The 2001/2002 4.3's use a shaft rocker system that looks to be real trick... more like the jesel rocker shaft system, and they have roller bearings in the trunions... as soon as these heads and rockers become more available in the "used parts system", this may be even a better low buck, trick of the month.
