rear coilovers
TeeTopZ
Re: rear coilovers
http://thorbros.com/catalog/4-link-kits
This is intended for the lowered crowd, but they have weld in and bolt in 3 link (like the one above) and weld in 4 link kits. In the pic above, the coilovers are simply mounted to the lower link bolt and the factory upper mount. A little fab work and I think these kits could work with coilovers. And they are readily available. Just my :2cents:
gt67sy
Re: rear coilovers
Here is the Sportmachines kit bolted in my syclone kit is great and a beautiful piece, as far as I know they are available as I'm pretty sure I have the first kit released to the public
Re: rear coilovers
My only word of caution on putting a new suspension on the back of any car, is to understand the physics of what you are doing. It amazes me at some of the low rider suspension designs, and although some look cool, for a performance application they just plain are horrible geometry and can be flat dangerous.
Cruising the local waterfront going 5mph, as you bags are lowered, scrapping your metal plate on the ground it probably does just fine.
Go to the track and run 100mph, and let me know so I can avoid being anywhere near you.
Before anyone invests money, do basic google searching on 4 link geometry, instant center, roll center, anti dive, pinion angle. No need to be an expert but get some knowledge before you spend your hard earned dollars on something that might be total junk.
hatrik8
Re: rear coilovers
Can a rear sway bar be utilized? or is it not needed?
I have the beltech front and rear sway bars on my truck now.
Re: rear coilovers
To add a bit more, the basics of any rear suspension is the Instant Center. Below is a very basic graph. Compare it to any design you see listed anywhere.
Ladder bars are the front pivot point.
Leaf springs are also (usually)
A lot of low rider suspensions totally disregard this, you will see the instant center behind the vehicle, which for drag racing is not a good thing. I've done it on my own typhoon on accident, it spun badly at the track, I thumped my chest thinking I was making a ton of horsepower, the track sucked, etc. It wasn't any of those it was the setup of my suspension.
This site has good information a beginner can understand.
http://www.how-to-build-hotrods.com/tuning-4-link.html
Now for those wanting to race around turns/cones etc then Roll Center plays a big part, something even my own typhoon could stand to be adjusted right now. (of course it has to run first)
Re: rear coilovers
Ok, if you can't tell I have a big passion for this topic.
Below is a video that shows what happens when the Instant Center is in front of the neutral line. (or I can assume most cars are setup that way)
Now lets compare this to a buick GNX (must be GNX as they added a bar to move the Instant Center behind the neutral line). The rear of the car actually move UP not DOWN.
Fast Forward to 19:30 Minutes into this video
So the next question I have asked a lot, and done a lot of thinking about is what does an AWD vehicle need. My best theory is we want the IC right on the neutral line, or just barely in front. Being we have the front tires pulling, we don't need to waste time/energy of the car moving backwards and benefit more from keeping all 4 planted evenly. (This is my opinion and I have had well known suspension expert tend to agree).
TeeTopZ
Re: rear coilovers
Good info about the geometry. I never figured the low rider kits were the best for that. Now I know. However, some of the bracketry they have could be a good starting point for a well thought out homebuilt setup
Logan
Re: rear coilovers
So I guess my question is this, are we saying that the Sportmachines kit is a step in the wrong direction for our trucks?
gt67sy
Re: rear coilovers
Yes a bell tech rear sway bar is probably the only one based on some measurements I've taken. I will be trying to install it on minr
ZavzTy547
Senior Member
Re: rear coilovers
We are working to make it a full bolt in affair. We have some more test ing to do but preliminary calculations, looking at $1200.
Thats for the bolt in 4 link. The hardware. Single adjustable coilovers, with springs, and ends, ready to install. IF you wanted a specific color for Powdercoating or additionals, that would add to the cost.
Subscribed - Keep us posted!
Windedv6
Ty n 10s
Re: rear coilovers
Jeff is correct on this...
Back in 2006 I posted this when I did my rear coilovers...
I am not here to throw cold water on what sounds like a hot setup, but I was going to do a 4-link a few years back and ran into a couple of issues. The concerns were mentioned by people that did chassis work for a living...rails, door-cars, pro-streets, etc.
Us sy-tyer's have a couple of problems. If we mount a 4-link out-board we hurt our tire clearance. If we run them in-board we hurt our streetability and cornering. Inboard is ok for straight-line racing and somewhat ok for a street sy, but the ty is side heavy and in-board is not good for them on the street. If we center the bars under the frame in a Ty we can't get any clearance for travel, unless there is some frame notching done. 4-link on a ty without back-halving as been done, but not so sure how well it turned out.
The other, bigger reason is the fact that our AWD doesn't need "lift" from the front. Transferring weight off of the front is what is killing our handling at the track. It's been proven that when we keep our front planted, and weighted, we are more stable out of the hole and it helps our 60 foots.
I had Dunstan Performance experiment with a bolt-on 3-link bar several years ago. It was to short in length and had about 1.5 of frame clearance. I was a disaster trying to hook up. The front was coming up and the rears were unloading way to early. Couldn't get any better than mid to high 1.6x.
The chassis shop that did my current setup worked with Competition Chassis to come up with a long three link bar that came forward to the door pillar, closer to the instant center of the truck. This dropped the rear weight of the truck on the tires with out unloading so much weight off of the front...as well as allowed the weight to hang back there longer. Have pulled some 1.4x with a 4,150lb ty.
If we want we could have a 4-link setup pull our heavy front ends off of the ground and transfer a ton of weight (literally) to the rear wheels. But then what is the point of AWD? Just more weight to haul down the track? In a perfect world we would want all four tires to have the right amount of weight to each tire patch throughout the launch. Hard to do though.
John
The setup has been great for 60's and it corners like its on rails. The bars are mounted on the outboard side of the rails and I have the 315 tire setup with no clearance issues. The shocks still maintain the original location pocket and Typhoon fuel tank stays in the original location.
If you watch my videos at launch, it comes out smooth and straight. Barely any lift at all in the front and little to no squat in the rear.
John
