Re: Radiators...whats best?
Coming back to me now..
My truck was a 95 TBI (Z Vin).. it had 2 knock sensors... seems like one of the knock sensors may have had a pigtail on it while the other didn't.. the sensor posted in the pic was the coolent temp, above it would have been a knock sensor. The Knock sensors where only a single wire, they gain there ground through the block.
Just an FYI..
What I mean by obd1.5 is that it had a ob2 hookup, but the electronic behind it was obd1.. the computer was under the dash...
In GM engines, the ECT ("computer") sensor is always mounted in the intake manifold adjacent to the thermostat so it indicates an average temperature of both heads.
The knock sensor is usually mounted in a "wet" hole because sound is better conducted through liquid. Not all "2 hole heads" have both holes exposed to water. Some early heads have dry holes, and are often not plugged.
The CPI L35's like the SonomaGT have 2 knock sensors. There is one on the rear of the right cyl head mounted in a dry hole. The driver's side head knock sensor is in a wet hole, and the temp sensor is on the passenger side. The sensors are wired in parallel to a single input in the ECM. Either sensor can trigger knock retard.
I'm not aware of any other sensors installed on the heads.
Just an FYI..
