SYCLONE#1531
'MOFOFAST
I just received my powerglide empty case yesterday from bte. Done some test fitting and decided this is the route I will be going! Spacer tfc adapter will be from jw which i will have to lengthen to aprox 8 inches. Im going by sopport bar mounting length to get spacer length. Should be able to use stock crossmember being total length will be the same as stock. Only other mod will be shortening output shaft aprox 2 inches. This will still leave plenty enough spline length. I will most likely b using a BTE (1.98 )glide with aftermarket case.
http://www.bteracing.com/Transmissions/Powerglide-Transmissions/BTE-Top-Sportsman-Powerglide.html
