post your best 60ft on a stock truck at the dragstrip
Raist103
Re: post your best 60ft on a stock truck at the dragstrip
1.68 to 1.72 avg
blk00z28
Forced to by choice
1.73 at OSW right after a car blew up in the middle of the day. That was on a 12lb launch.
Xtrempickup
All turbo All the time
whats this neutral rev about? neutral the motor doesnt have any load on it, are you revving it and then manually putting it into drive to launch? wouldnt it just be better having your foot on the brake and the other on the gas and just trying to hold it down so it doesnt take off . obviously easy if you have the hydro boost but brake boosting is what ive always known about with automatics and more or less neutral revving with a 5spd before dumping or feathering a clutch at launch
BigBadSmoosh
neutral rev builds more vac in the engine, which inturn allows the brakes to hold more at the line..
Flyin Ryan
hated cuz he drives fords
reving it creates more vacuum which the braking system works off of.. so more vacuum more holding power
tbauer03
TRBOBOX
Gosh all this reading about boost launches makes me want to go take out a student loan and spend the cash on a new tranny
cloneman315
do a dry hop be4 u stage it helps alot ,put homemade limiters on the front and drop the tires to about 22 and u should see some gains
Typhoonracer
Old Guard GURU
1.67 back in 94-95 just after i got the truck....total stock....i think it was one of the first times I raced the truck after i got it.....
Michael
Mine has run 1.83 60' with some wheelspin. It ran that in NC on a really crappy track (and 95°F and 90% RH) with a 10 psi launch & 22 psi in tires. It ran the same best 60' here in Oregon at 4 psi launch on a moderately crappy track (2nd race of the season, 6 weeks after 1st race so it might as well been opening day), 27 psi in tires. My brakes are not working well right now, so 4-5 psi was all I could hold consistently. Planning to go back to bonded rear shoes with large shoe front and rear (buying 2 sets).
Regards,
Michael Pliska
