post your best 60ft on a stock truck at the dragstrip
Bad00SS
Post up the best 60ft times you have seen on a stock truck at the track.
i recently took my TY to the drag strip to see what she ran in stock form. I noticed my launch was not so great compared to other trucks i had seen in the past. It was extremely busy and i only got 2 runs in. my 60fts were both in the 1.9's. while tryin to build boost at the line the truck would either push through the brakes or try to spin the rear tires while the fronts were locked, at which point i backed off the gas a bit, I was worried about my transfercase.
so whats the expected 60ft on one of these trucks.
93 TY 2185
Re: post your best 60ft on a stock truck at the dragstrip
Check out the timeslip database
http://www.syty.net/forums/timeslips.php?
Define stock, not many "STOCK" trucks are raced.
If your not in the 1.7's you got some work to do, brakes, technique, something.
Bad00SS
it is 100% original stock truck with the exception of a k&n filter. I had the spare tire and everything in the truck.
Are you reving in N to build vacuum in your brakes, before you brake torque the motor? If yes, pushing the lights is usually a front brake problem (air in lines, pads or need new calipers), spinning rears is usually a rear brake problem (7/8" wheel cylinders)
sy2675
He Saved the Pimp'n Game!
my best 60 ft is 1.64 spinning the tires
turbodog
I turned some 1.7X's at nats 03 in stock class.
12secondSY
Syty Killer :(
1.74
stock with free mods
tires that I think might have been factory(bald and old for sure) with slight spin
That was in my syclone
turbodig
I'd say that's about average for a 100% stock truck, without sticky tires. and stock stall.
1.8s are generally considered good.... 1.7x is very good. If you have the late factory converter, a 1.9 isn't bad.
Tighten your rear brakes up via the adjusters, and make sure you do the "neutral rev" manuever before launch.
Jimmy
Banned
JKsSyclone said:
My wife cut a 1.68 in our bone stock Ty.After Jimmy taught her how to launch.
Fixed that for ya bud.
THEMADTYPH00N
Brad, I told you Sunday at the drag strip exactly what they are telling you in this thread.
Bad00SS
after the fact i did try putting it in nuetral and reving it and holding the brake pedal down farther then launching, as you told me justin. it seemed to work a bit better, but it was on the street so i dont know. regardless i think the rear brakes need adjustment. i cant stall it up very high without it trying to spin the rear tires. sure the fronts will allways hold now that i know how to rev it in nuetral then put it in drive....but it doesnt do any good to try to build more boost if the rears are still spinning.
nastety92
1.61 and 1.62, but it only happened once or twice.
Should happen much more consistantly next season.
Nick
AUSyTyIN
Unbusted $#it box
Horrible 1.99 with 6+ year old dry rotted tires :lol:
But I have new ZR1's wrapped in some decent tires now, so that better be at least a 1.8x now
Silly
Banned
Come on out next time I am in town and I will show you how to do it. :)
Bad00SS
You havent driven yours for so many years, are you sure YOU still know how to do it? LOL.
sounds good mike. Let me know when your around.
Luke
Fish sticks SUCK !!!
1.80 with bald ass tires, bone stock with reliability mods
