Plug n Play ECU
MotoCam360
Since the vendor section is gone, I thought I would provide an update on our MS3 Plug n Play ecu project here. The provisions for tranny control have been included in our pcb layout (red board) with the oem connectors, so we just need to build the circuit and tune it. The system is shipping now, so if somebody wants to upgrade their tranny down the road, the ecu box can be sent in and easily populated for this functionality.
MotoCam360
Re: Plug n Play ECU
The board is an MS3Pro board + plus we've added tranny control + the SyTy OEM factory connectors for plug-n-play.
$1999 for the base unit
$2499 with tranny control
We can supply the E85 sensor and wideband 02 if you need it also. We ship the unit with a base tune for a stock TY preloaded so you can be up in a matter of minutes.
TYTILIDIE
METH HEAD
Re: Plug n Play ECU
What is the advantage to this over something like the Dominator at a similar price?
MotoCam360
Re: Plug n Play ECU
The advantage of this system is a 3 minute install without having to hack up your factory harness. Since it comes with a syty base tune preinstalled you could probably get this system up and running faster than you could do an oil change.
atkonkler
Is this your bush?
Re: Plug n Play ECU
Who does the fine tuning? You or me? Does it come with software if I have to tune it?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Brianawd
Re: Plug n Play ECU
What kinda safety features does this have.
Also does it do target AFR. Is is set up for low or
High impedance injectors? Built in 2step?
atkonkler
Is this your bush?
Re: Plug n Play ECU
If there is a different turbo than stock can that be incorporated into the base tune?
MotoCam360
Re: Plug n Play ECU
Actually the system uses very powerful tuning software called Tuner Studio MS, which can be downloaded here for free (the lite version):
TunerStudio 3.0 Features by Edition | tunerstudio.com
And yes the hardware and software can easily accommodate different turbos, different fuel types, different injector sizes, etc, etc
Brianawd
Re: Plug n Play ECU
Do you have this on a syty running?
I'm really interested. I have a dominator set up
Ready to be installed but I'm really liking the plug
And play! I would just like more info on the test
Syty this is running on now.
I know you said auto tune. But also does it do boost control. 2step. Boost by gear
Flex fuel and so on
MotoCam360
Re: Plug n Play ECU
Yes the Stage 1 kit is running on my '93 TY now. We are wrapping up Stage 2 this month which consists of a crank trigger with a coil pack to completely eliminate the distributor. Stage 3 is sequential injection which only requires running an additional cable to the ecu box.
Yes the MS3 supports boost control, 2step and boost by gear, and I have E85 flex fuel on my truck now.
As you know the Dominator is a good setup, but I think we have an advantage in the time to install and the ability to put a syty back to stock form because none of the factory wiring is really disturbed.
anryo
Re: Plug n Play ECU
Are you planning to sell only the crank trigger kit? Would it come with trigger wheel and all the rest of the needed hardware?
MotoCam360
Re: Plug n Play ECU
So where is your website?
I am slightly interested in this setup.
We just paid a company to rebuild our site (which was hacked) and they said it will launch in 2-3 weeks. It will be:
www.MotoCam360.com
We'll put up all our hood strut kits, plug n play ECU kits, coil pack kit, sequential injection, 4L80e tranny control kit, etc, etc
