That cap look eaten up just for the break in. I would try a different dis. and see where that gets you. I would just put a stock one back and and see what it does.
Well, I'll be dipped in shit.
After seeing your post in the other thread tonight, I was going to suggest that you try a stock distributor, because I don't trust MSD. But I remember in the beginning of this thread, you were certain that it wasn't the distributor, because you had faith in your MSD
I just spent over 2 hours reading every post looking for where you tried a stock distributor. I didn't want to look like an idiot that can't take two hours to read through 650+ posts making sure you had not tried the obvious, yet.
And while I was reading, you put up you're going to try to get one to try. I really can't believe you didn't try this long before now. Code 42. Won't start. Changes with temp (semiconductors change state with temperature). 6,000 RPM indications when cranking. Engine floods when it's given this much fuel. Not recognizing that the lean indication on the PLX and O² are indicative of ignition misfires, and not of fuel delivery deficiencies.
If you can't get one, I'll pull the distributor out of my Syclone and send it to you to try. Just promise to send it back.
Dude, I can loan you a stock dizzy-being my truck is on jack stands.- Cap and rotor are fresh too. :tup:
Just don't tell me you live in South Jersey...
Watching Jersey Shore on MTV. :rotf: I miss Jersey!
When you have the distrubtor out take the time to put a light down the hole and check your cam gear. A flag went up when you mentioned that the stock gear was worn. Spark scatter caused by worn gears will play havoc with your timing and tune. Also your cap has telling signs of alignment changes. Easy to check the cam gear with the distrubtor out.
John
I would have to figure out to go about doing this or if this could even apply. Any thoughts from the other gurus?I had a 91 Z28 drive me nuts one time with about the same issues. I replaced just about every thing you have. module-pick-up, ecm, inj, What it turned out to be was the tach board in the cluster was shorting outing the signal at the coil somehow. if it's possible try and unhook the tach wire to see.
I'm still thinking about your nightmare and what else it couldn't be!
