Quickstop [UK]
Combating adversyty.
Re: One last shot... Breaking up!
new ign module?
new ign module?
new ign module?
Took out the 1 year old one MSD ign module and put in a new Accel module along with a new magnetic pick up. My symptoms point towards ign module but I changed it. Unless there is a specific one for a sy/ty and I don't have the correct one?
I'm going to verify my TDC mark on balancer but the truck idles at 29 degrees. When I bring the RPMs up (in park) timing rises to 44 degrees which to me seems awfully high! I'm also at 17 degrees or so at WOT which seems normal. What do I know? Nolan the tuner doesn't think anything of it...
Base timing is supossed to be set at 0 degrees with brown wire disconnected. That's what mine is set at. It runs at 29 deg with wire connected at idleThat to me is way to high I am not sure what base is for these trucks (Still learning) But Id say 10* maybe would be right with the wire disconnected ?
have you verified that the TPS sensor is reading linearly all the way through the sweep? No flat spots? Look carefully at that...make sure its setup correctly and reading linearly.
Get Bezerk on a flight over there.
Or Jeff Scott.
I want to know what this is. This saga reminds me of the thread with gjp and his syclone woes a year or two ago.
Have you read his thread?
idle misfire
Rob if it was faulty O2 why would I still have the problem with the O2 disconnected. At that point the truck is in 'open loop' and the O2 sensor is not controlling fueling. I have the factory O2 wired to the ECM and the WBO2 is wired to the ECM for datalogging purposes only. I've never tried to check the purple wire for coninuity to ground but it making connection with 0 resistance to the ECM.
