Oil Cooler Lines
Static
My oil cooler lines are leaking pretty badly and I'm going to replace them when I do my oil change. Rockauto.com lists 2 different ones, does anyone know which part number is the one I need? Also this will be my first oil change on this truck what type of oil should I be using and what is the capacity?
Windedv6
Ty n 10s
Re: Oil Cooler Lines
Oil cooler lines. You you refering to the lines that go from the filter to the radiator which are the cooler lines. Or are you thinking of the lines that go between the block and the filter which are the ones that seem to start leaking when these trucks get older?
John
gkrcr882
SyTyless......for now!
De-grease everything and verify where the leak is coming from. On mine, it was the $6 gasket between the lines and the block that began to leak, and almost killed my engine. Its a little louder now, but still running. From what I've seen, that's the leak point. Those lines aren't fun to replace, so verify the leak first.
Normal oil capacity with filter change is ~4.5 qts of full synthetic only!
Static
Curious as to what you found with your ABS in this thread? Several peeps responded to your request for info. I spent over an hour writing my reply. Rather rude to never acknowledge, or follow up on a thread that requests help, and is given......
This is a small board. About 75 posts per day. Threads and replies don't 'get lost' in the volume. We try to help each other, including noobs. A little gratitude goes a long way....
I really appreciated your post. I actually printed it out so I can go over everything step by step. I just haven't responded as I had no new info to report. Ive been in pain from a kidney stone for the last 2 days and have taken a bunch of pain meds so my head isn't really straight to be working on troubleshooting. I'm just trying to forward my truck repairs best I can by ordering parts while I'm down.
John
I need the ones that go from the filter down to the block.
Windedv6
Ty n 10s
Those are not the cooler lines. Those are the oil lines that go to the remote located oil filter. I may have a low milage set. I will check tomorrow.
John
Static
Ok I give. Whats the trick to getting the filter to block lines changed? Ive unbolted the sandwich adapter and dropped the front diff enough to move it toward the drivers frame rail. I thought i could sneak it out one way or the other but cant get it to go anywhere from there. Looks like the diff has to drop down further but I cant seem to get at the nut that resides in the drivers frame rail. Any help?
Dont mean to hijack but anyone know the part number for the gasket on the block to the oil lines?
Depends. If it's o-ring style most parts stores will have them as a kit which covers the the line (block to filter) and adapter to block. Sorry don't have that number. The number I DO have is the kit for the non o-ring style seals.
EDIT o-ring kit should be GM # 15564870
HTH
Dorman Part No. 66201
http://www.amazon.com/Dorman-66201-Cooler-Line-Gasket/dp/B001HZNT4G
BTW If you take out the wheel well, taking out the pair of lines block-to-filter is a semi piece of cake. Worth the time in my book. They need to twist down to come out and the wheel well is in the way.
Ty#365
BOOST LAUNCH KING
I cut mine out and went to on the block filter.No more oil leaks.YAY!
Static
Got it done this afternoon. Ended up cutting the old ones out with a sawzall and then fished the new ones in. Thanks for the help.
Darin
Myself inlcuded.
I use a filter for a 2.2 4 banger S10. You kida have to get it in from the side above the front prop shaft, but it fits without hitting anything.
Same diameter as the 4.3 filter, but shorter.
Ty#365
BOOST LAUNCH KING
I am using a WIX 51040. It is made for the 2.2l S10's and cavaliers. Its working out good so far.
Older thread, I know. But I'm working on my DD and need to replace the oil lines while it's on the lift. I found all the P/N's, but want to put them in one post. So I can find them easily next time. Here they are:
Oil hoses from block to filter adapter: Dorman 625-102 or GM 12472311
Oil hoses filter to radiator: GM 12472307
Seals for lines to adapter and filter stand. (3 places) Dorman 66-201 or GM 15701719 (Need 6. Come in a 10-pack)
Gasket kit, Lines adapter to block (1 o-ring, and 1 gasket) GM 88893989 (new number)
(Dorman does not make a hose set for a SyTy. Or a SoGT, for that matter)
There they are. All the oil lines and seals.
Are you sure about Dorman not making a hose set for the Sy? I believe the 625-102 is correct and will fit, I've used it. Or did I misunderstand?
See my thread for some pics:
http://www.syty.net/forums/showthread.php?t=68031&highlight=dorman
2500avalanche
Well-known member
I tried that "88893989" number at Rock auto, and it can't find the part. What is the old part #?I need to order that gasket kit (adaptor to block)
Thanks
Dorman does not make a filter to radiator hose set for a SyTy. Or a SoGT, for that matter. Only the engine to filter set.
Why not try the local dealership? It should be under $5
They have it at Summit.
http://www.summitracing.com/parts.aspx?sku=NAL-88893989
Have you tried contacting Mike Hood? He may have them/be able to get them for you, also.
Rockauto shows Dorman PN 82560. Not sure if this will work, though.
Oil Adapter and Cooler Gasket Assortment Contains all the o-rings and Gaskets to seal; GM, Chrysler and Jeep oil filter adapters and oil cooler lines
getimage.php
s_blazin
accidently came upon this list on napas website tonight and thought it might be an idea to post what i found.
in this search i believe number 3 4 and 5 down are whats required for our trucks to replace the radiator to filter, filter to block and the o-rings, if i'm not mistaken?
hope this helps somone and also wanted to mark them on a post for easier finding
http://www.napaonline.com/Search/Re...ler&Ntk=Keyword&N=599001+101991+50030+2030021
or
http://www.napaonline.com/Search/Detail.aspx?A=BK_8232232_0077405822&An=599001+101991+50030+2030021
http://www.napaonline.com/Search/Detail.aspx?A=BK_8234068_0115829207&An=599001+101991+50030+2030021
http://www.napaonline.com/Search/Detail.aspx?A=FPGES70016_0159346411&An=599001+101991+50030+2030021
on another note does this stuff go bad and start leaking that often? my truck is still apart right now and it's all accessible (more than when it is complete) but i'm not sure it's worth replacing since it all looks to be in decent shape?
