Syclone#2960
What ever it takes!!
The ty is not getting fuel to the cylinders.
I checked 3 fuses ECM's & IGN.-Good
Fuel PSI is 35 & I can hear the fuel pump prime on tuen key status.
I disconnected the #1 fuel injector wire plug and ran a test light to ground. Then with the ign turned "on"...I'm getting a light at both wires.
Is this right?
If I spray starter fluid through the TB it will start to burn the fluid but the injectors must not be firing cause it shuts off.
Is this right?
