Need help with numerous typhoon issues!
TURBOJESUS
Hey there folks, bear with me on this long ass post. I need help figuring out the origin of the issues on my father's typhoon. It's number 663, made in December of 92. He drove it for almost two years after he bought it without issues but then he burnt up the starter wire and just parked it. When I fixed that issue last week, I noticed while doing a routine tune up/fluid change that there were numerous boost leaks in the intake tubing system and that I also fixed(I just looped all the larger tubes on the throttle body, but the FPR and MAP sensor were already hooked up right), and that the fuel filter was on backwards, which I replaced with a new one pointing the right way. On the first test drive the turbocharger failed almost immediately at almost no boost. The compressor housing and wheel made mild contact and the bearings smelled of burnt oil.
Being a fabricator, turbo hoarder, and lucky as ****, I was able to grab a low mile holset H1C with a twin scroll 12cm t4 housing out of my barn and bolt it up with a handmade 3.5" TIG welded mild steel downpipe and modified oil drain tube. This turbo flows about 550cfm efficiently. That was easy. Time for boosted launches. YEA RIGHT. ha.
Ok, so it now cuts out totally, almost like a fuel cut/rev limiter when it hits any boost or goes past about 60% throttle position. I'm stumped
Also, this truck has a large aero motive fuel pump as I recall and bigger injectors. I don't know how to check if I have the 1,2,or 3 bar map sensor, but it has a piggybacked chip on the ECU with all its labels too faded to read��, and a turbo timer that is disconnected. I don't know what it takes to read codes, test the ECU for proper function, or much else that doesn't involve hand tools (again, My primary experience is as a fabricator not a mechanic, professionally)
I'm located near Huntsville Alabama, if anyone proficient with a sy ty or GT is near. I WILL pay for help. Gotta get this girl running, paint it, and sell it before I get paid so I can't **** around.
Quickstop [UK]
Combating adversyty.
Re: Need help with numerous typhoon issues!
To post pics, open a photobucket account. Upload them. Copy the IMG link for the pics and paste it here.
Do you have a catalytic convertor? Check it hasn't clogged.
MAP sensor has writing and numbers. Post them up.
Pics of the chip - same with that.
I'm gonna delete the other post as these are tuning issues mainly.
TURBOJESUS
Oh I see! Okay I can do that. And no, it's got only the 3.5" downpipe on it currently.
Quickstop [UK]
Is your check engine light on? To read codes, get a paper clip and put it in the ALDL terminal under the dash. Pins A and B will give you a code that flashes in a sequence three times when the ign is on. Don't start it, just accessories. That will help.
You can search on here for a thread telling if it's a 2 or 3 bar MAP. Those numbers give it away usually.
Quickstop [UK]
Sure all your vac hoses are correct?
Are the wires new? What gap are the plugs?
Does it start and idle fine or is it a hard start?
TURBOJESUS
Okay so I just saw that sticky, it's looking like that's he old part number for the 3-bar sensors? Pics of the computer coming momentarily.
TURBOJESUS
Doesn't wanna start without ether, isles like shit, doesn't like to get as hot as it should. I'm about to pull the plugs and replace the thermostat this evening or tomorrow. The wires look like some old shitty parts store units.
Quickstop [UK]
Can you paste the IMG links in this thread? The pictures will appear. That link on my phone opens up the album then loads of pages of spam.
Probably a Pitbull or Kenne-Bell chip. Can't see yet. Keep digging. Wires sound like they need some attention. What fuel pressure is it set at? Key in, engine off, IGN on for 2 secs while the pump primes?
The chip with ribbon cable is an ultimate chip. What are you running for spark plugs? Gap, brand, part number. I would check the fuel pressure at boost.
TURBOJESUS
I'll pull them today and check. How did you identify that chip? Just curious
TURBOJESUS
Ok and it only PRIMES to 19 psi but it holds like around 40psi once it's running, and doesn't dip out when the power cuts. Also I think it has lost its valve guides or something as well and the white smoke has turned more distinctly blueish and is now accompanied by a steady oil drop in the exhaust����������������
The memcal (pictured above) looks like it is marked with aybm which means it is stock.
Gnocide
turbo game burt reynolds
if fuel pressure isn't at at least 35 to 40 that truck will not idle and will shut off
The memcal is the blue carrier that has the esc circuitry, ROM, limp mode programming. It is often called a 'chip'. The ultimate chip you have was bypassing the ROM and using a different its own source code and look up tables. The ultimate chip use the rest of circuit try of the memcal.
My experience is that injectors need about 30psi of fuel pressure. The 50# ultimate injectors programming asked for 40# of base fuel pressure this is about 30psi at idle. The couple time I fooled around lowering pressure the injector stopped firing reliable around 26-28psi. I am sure this number varies by injector type and tolerances. Most people set the base fuel pressure which done by disconnecting the vacuum line to the fuel pressure regulator.
