leroy
Re: modified distributor rotor
You are right. Brain cramp.
Jim
skata said:no, doing this mod does not affect the timing. the timing is adjusted by rotating the distributor base. the magnetic points/ring under the rotor determines when the spark should occur.
if you do the rotor mod, nothing else needs to be done.
this mod just provides a better spark path when the ecm is really advancing the timing, ie idle and high rpm's.
Jim
