evberger22
BOOSTYD
Re: Map Sensors
Hey miles you should have emailed me about this, I just saw this post now.ha ha. It is in fact an electric boost gauge auto meter pro comp ultra lite. I had that gauge kicking around so I decided to throw it in that ty last spring. Yes the map sensor on the firewall was only for that gauge so make sure the same one is still connected to it and it should work fine,( the map with velcro on it). Yes it looks exactly like a gm 3bar as I am pretty sure it is because that gauge reads up to 30 psi. I believe you can set a little red light to come on when the gauge hits your desired boost setting, I think it also has a max recall button on it too. I had no problems with it, matched data master when I did tests with it. Miles I do have an exact match mechanical boost gauge in my garage I am not using and I can send it to you if need be. It is out of my other ty I switched to es style auto meter. Let me know.
