BoostedSUV
Re: I am lost...
I'm running 17.5psi with no knock with just about the same build on pump gas. You don't need any meth or h2o to run those those levels. Anyways, I was just curious where the boost was at. Does it hold 15psi? With a clogged cat it will usually reduce the boost levels. I had a clogged cat and chased the problem for 6 months before I finally discovered it. Truck had no power and hardly built boost.
