How to install stock arm coil overs
Re: How to install stock arm coil overs
George Blake said:
When you guys are doing these, how much are trimming off the bump stop?
I didn't take anything off my bump stops with a 27" ride height and tubular A-arms (I not sure how the stock A-arms and the bumps stops clearances are, they maybe be different.) I notice at 26.5" ride my bump stops were really close. You can always test the bump stop and cleck cladding clearance without the coil/shock set up.
oboym
smaug said:
I did not touch my bumpstops.
are you ridding on the bump stops.
also what did you end up setting the shocks at (set mine at 2 clicks)
BigBadSmoosh
not at all, right now mine at dead center.. they are a little stiff but they keep the truck flat around all corners..
syntax
How long can these shocks be expected to last with regular driving, im not familiar with coil overs, are they rebuilt or is the shock replaced?
MIGHTYMOUSE
Turbo F body guy
ok so if i wanted to do this in the next couple of weeks which kit should i get
E-Rue
theres tons of good info in this post. instalation photos, tips and tricks...... if anyone is doing this mod id recommend bookmarking this.
e
Kybol
Sorry, yeah they do, meant to say none of smaugs work though.
BigBadSmoosh
yeah my server died long ago.. e-rue has all of my pics though.
mog-10
does any one know if rpm or turbo time still offer the coil kits with out the a arms
i have sent a few emails to both of them regarding price and have not got a reply back from them
if any one can tell me part numbers of the springs and the q1a's that would be help full so i can order them from else ware
PPI Typhoon
DIY Madman
Figured I'd post these here too in case someone wanted some pics of what needs to be modified on the coilover spring seats:
BigBadSmoosh
good luck with that collar, the spring is going to hit the frame..
also need to ditch the poly bushings and go with solid metal ones.
PPI Typhoon
DIY Madman
I'll make it work. If i need to machine it more, I'll machine it more.
I already have the metal bushings.
EDIT: They do fit, minus the trimming I have to do as described in MRKING's first post.
I just have a socket extension holding it in there, but I just wanted to show that it does fit.
PPI Typhoon
DIY Madman
And here they are mocked up. I still need to get the spacers in there and the metal bushings, but that'll come tomorrow. I'm also replacing the bolts/nuts with new parts. The originals are pretty cruddy.
But for those that said they won't fit.....
AND.......they are right side up!
TYRODD
My ass. Look at it.
Ive heard of this being mentioned before, but havent seen many people "beefing up" the shock mount since it is taking much more abuse with a coil over setup. Any thoughts on this?
Dan, Im definitely going to have to check this beast out next time I am in the valley. Its a totally different animal since the last time I saw it! :)
The metal bushing is actually the heim joint style ends, not the metal sleeve that slides into the rubber.
We never had any luck with the rubber mounting, just too much stress.
Small pic but you get idea
