How do you acheive steady boost throughout the rpm range?
ZavzTy547
Senior Member
I've been fighting boost issues for what seems like forever, so I bought a gready profec spec II, thinking It would fix the flutuating boost but it didn't (same characteristics with the STG chip controlling boost also).
Example: When I dial-in the boost at 17psi, it will stay their until it shifts, then it falls off to 12-14 psi and start to slowly creep back to 17psi as the rpms rise back.
I thought it may be knock related but I checked DM and it only shows a couple of degrees during shift points. I tested for vacuum leaks and can't find any.
My voltage tends to drop while in WOT (to like 12.7volts). Could that be part of the issue?
I also noticed a psi drop when my TC locks up...
I'm suspecting ignition but I'm not sure were to start first. Any recomendations would be appreciated.
Thanks.
Zav.
bezerk
Re: How do you acheive steady boost throughout
you still have a cat on it?
bezerk
have you tried shortning the wastegate rod a bit?
He running the RPM stage 3 bolt on turbo if that tells you anything
http://www.raceprovenmotors.com/cart/product_info.php?products_id=418
TurboJunk
questionable
correct me if im wrong.....
but should the boost drop off slightly? as torque drops before every shift the boost level will decrease because it has used up the power for that gear.
5 psi is alot but shouldnt it loose like 2-3 psi?
SpoolingTurbo6
You can't build boost with out torque.But it shouldn't drop 5 psi unless the turbo needs huge amounts of exhaust.What converterdo you have?
TYTILIDIE
METH HEAD
It s very possible you dont the EBC set right. Whats your setting at? What boost are you trying to run? SET and SET GAIN work together with this type of situation. It takes a while to really get it where it should be.
ZavzTy547
Senior Member
I'm running a 3" Cat and a 2800 stall TC..
Profec settings:
My "SET" setting is at 37% which gives me roughly 18.5 PSI.
I've set the "SET GAIN" between 5%-35%. At 5% it will drop from 18 to 14.5 (roughly base boost). If it's set to 35% it will drop from 18.5psi to 15psi
Same characteristics with the stock solenoid/STG chip, so I'm assuming that the actuator must be out of its range and needs adjustment, since RPM stage 1-2-3's comes with the heavy duty actuators...
Does anyone have a right up on how to find this "actuator range" to control boost without the KABOOM factor?
Thanks again for your replies.
Zav.
TYTILIDIE
METH HEAD
If youre still dropping to 15, raise it higher. The setting that says GAIN , only, you have to be careful of. I leave it alone unless it spools too fast. What is the GAIN set at? Not SET GAIN. GAIN is how fast it will spoool up.
