Re: Highest boost level?
Don W. said:
Just FYI on steel pistons, look at the size of the pin!! Scroll down for 2 piece pistons, which have been around quite awhile actually in HD apps.
http://www.cat.com/cda/files/70471/7/PEHP7039-02.pdf
Ahhh, okay, I was just referring to the light-duty diesel performance guys. I have never been inside of one of those heavy duty diesels (although I used to drive Class 8 trucks back in college). I know the Cummins I used to drive was speed limited to 2000 rpm, so I wonder if it used steel pistons.
The tractor pull guys are running some pretty extreme stuff, upwards of 1800 hp out of a 5.9L Cummins. Not sure what their exact boost levels are (most of those guys are pretty tight-lipped about their setups). I mostly hang around with the diesel drag racing crowd.
Now to reveal my ulterior motive for learning boost levels:
Aside from being a longtime Typhoon owner, I am the engineering manager for ISSPRO, which is a gauge manufacturing company (known more in the heavy duty and performance diesel markets). We have a new gauge line out which uses an underhood controller, and a databus to communicate with the individual gauges (3 wires daisy-chained to as many as 17 gauges). A future upgrade will also offer some datalogging capability. I wanted to see what boost levels people are running on turbo gasoline applications, so we can come up with a sensor which will work. We use a straight pressure sensor for the diesel applications, but I wanted to run a MAP-style sensor for gasoline (so we can display vacuum as well).
If anyone knows a specific wide-range (3.5+ bar?) MAP sensor brand which is reasonably priced, I would love to hear it!
Thanks,
Michael Pliska
