Higher Amp Altenator
Syclone#1992
SyTy.net Moderator
Any pros/cons with this upgrade? Anyone notice a voltage increase at WOT? Will it hurt anything to upgrade to higher voltage?
Let me know your results/experiences.
TIA
Thrillhouse
I put a 115Amp in my blazer. Been working just great. If I remember electronics correctly there should never be any voltage spikes coming from an alternator due to the fact that it isn't a Generator and rotational speed doesn't affect its voltage output. I havn't actually measured my voltage at different throttle levels, but if the gauge is any indicator its a solid 14.4 at any RPM
phoonTy
Truckless. For now.
I can't give you any specifics on my alternator, but the previous owner of my Ty put in a 160amp to push a stereo system he had in it. From what I can tell, it doesn't do anything abnormal. My voltage always stays the same. Don't know any reason to upgrade to a higher amp alternator unless you're pushing some serious electronics inside, such as stereo or a/v stuff.
Here's a pic of mine, incase you're curious as to fit. It's not a close up of the alternator, but you can definitely see it poking out. :D
Falco
I've a Powermaster 140 AMP alternator. I'm very pleased with it. Voltage went up by almost a full volt.
Peace,
Windedv6
Ty n 10s
I have a 200 amp large case alternator (previous stereo comp vehicle) with an adjustable external voltage regulator. I can set my voltage up to about 16v. I am not sure how our truck's electrical system would react to such high voltage, but a steady 14.4v is were I have had mine set for a number of years. No problems with the stock ecm or speed pro (currently using). Our fuel pumps run stronger with the higher voltage.
The max voltage of our alternators is set by the manufacture or rebuilder. You can have an alternator shop modify one for higher voltage output.
As long as the alternator has enough amps to cover the truck's draw your volts should stay stable at the set voltage. I am sure most of us turn everything off but the nessessary lights, etc when racing at WOT.
Our stock alternators are ok from an ampere standpoint at WOT with minimum draw (no extra load from stereo, fans,,etc., but the output voltage from the factory settings vary from truck to truck. I have seen some above 14v and others in the low 12s.
Also remember that putting an oversized pully on the alternator or an undersized pulley on the crank (for a small amount of hp) may cause a loss of voltage at lower rpms. IMO I don't think there is enough hp gain to offset for the voltage drop that our small amp stock alternator puts out. If you feel that there is something to gain by resizing the pullys and slowing down the alternator then get a higher amp alternator and an adjustable external regulator. Set it to 14.4v after you changed the pulleys.
FWIW I think sending the stock alternator to the shop and having it rewound to 140 amps (about max for a small case alternator if you want it to last) and have it set at 14.4v (or modified for an adjustable external regulator) is a smart mod.
John
