Re: High Idle
When i reset the IAC, i can feel/hear it spinning. so i'd imagine its working. also in the time period when the IAC is open, the rpms do fluctuate, not alot, but some.
The TB, plenum, and intake gaskets are brand new, EGR and egr gasket are brand new. All the intake and plenum bolts are torqued to spec. Like you said, i tried the starter fluid spray, with no results. I also tried to isolate the plenum vacuum. I disconnected the fron plenum vac port, and put the gauge there, but i left the rear port, cause thats what feeds my MAP, and fuel press reg. and the system was low on vacuum.
Again, this is a custom cam, 115LSA, and 575 lift. so the vacuum numbers should be low.
Yes the truck didi idle on this IAC valve last summer, and yes, since the rebuild, the truck has had the high idle.
Datamaster read the same vacuum at the MAP sensor, as i did with the gauge at the MAP sensor.
Throttle blades are as closed as they can get.
Havent checked my RPM brake booster hose. but i dont think its leaking, its pretty heavy duty.
I know SBC's idle at 4~6 degrees advance. at my 1800rpm idle, the advance was 22 degrees. But since, i've dropped the advance down to 1 degree, and the idle only dropped to 950, so spark advance might have aided the high idle, but its still pulling air from somewhere.
Maybe the turbo is too big, and i'm Forcing to much Induction. :lol: :lol: :lol:
