Headers
sy1356
Re: Headers
Make sure that the headers you get have enough room for the knock sensor to clear on the left head. The previous owner of my truck installed Headman headers on my truck & the knock sensor will not fit at all. It was just left out. This is one of the many reasons I have found that my truck runs like poo.
mattw
Re: Headers
Relocate that sensor. Or build a bracket so that it can still mount on the head. That engine noise will travel through anything securely attached to the block so you can be somewhat creative if necessary...
Your ECM is doing a check(advancing timing and looking for knock). Once it fails that check you go in limp-home-mode with severely reduced power...
Brassmonkey
Cruzin' Mel Man
Re: Headers
Sorry, I thought you were talking about a knock sensor on a SyTy.
Icarus-54
Donating Old Member
Re: Headers
I've had them on my S-10 for over 10 yrs. now,never had a problem.However I do take them off and sand blast and repaint every 4 yrs.I'm also running the cpi motor and never had an issue with the o2 sensor.
Jack
sy1356
Re: Headers
I am going to put back the factory exhaust manifolds as soon as I find a nice set. Doing this will also eliminate some other problems I am having.
AirRideFanatic
"O-Dogg"
Re: Headers
Jack
I have a set of (very similar, to the Hedman) Sanderson headers for my clone... (same ones are currently installed on the 1992 LT1, now- but they have corroded to the point, that they're LEAKING, bad enough- I'm afraid to drive it, until we install the new set) That's awesome you sand blast them and repaint them, to ensure that doesn't happen.SIZE="1"] (do you do the sand blasting yourself? If so, that's cool- wish I had one of those, ha)[/SIZE]
I would do that, but (obviously) the motor-mounts are all custom and the way the V8 is sorta crammed in my Tyclone, I don't want to have to remove them every 4 years like, due them being installed on such a different application.
What do you guys recommend for coating headers.. ? Like, the BEST way.. to know they will last... for sure. Jet-Coating ?
91GT- you mentioned Ti-Tech Coating...? How much do you suppose that would run me to have the steel Sanderson one I have now (part # CS11-4x4) coated ? What sucks is… the “coated” version, directly from Sanderson is only about $100-$150 more. Why do I have the feeling I am going to pay a lot more than that to have them coated?
