Mephisto
These trucks are cursed
Re: Head Gaskets?
That makes sense... but wouldn't there have been a loud noise or some obvious indication that I had put a hole through a cylinder?
Also as a point of reference, the oil looks normal, smells fine, and doesn't show any indication of water/coolant mixing into it.
The few people I've talked to outside of this site all seemed to think it's the head gaskets... but, we could all be wrong too.
PS, sorry for totally hijacking this thread, but I do have a Saudi Ty... so...:rotf:
I am no expert on this subject. But I will post what my thoughts are. And they may be totally wrong.
My thinking is if you are getting 0 compression that you would have a hole in your piston. I don't know if possibly a head gasket blown out say to the outside of the engine from cylinder 1 and 2 could cause a 0 compression reading or not. I have never had this issue. But I would think if this happened you would have coolant/oil flowing from this spot.
I would think if you have a head gasket blow out between cylinders. I would think you would get a compression reading. But they may be a lower reading. And both of those readings would be almost the same compression reading.
Again this is just my thoughts so I could be totally wrong.
