Neelsonwheels
I recently had a problem pressurizing the coolant system on my truck. After exhausting all
other possibilities I came to the conclusion that I have a head gasket breach. I tore the engine down to the block and took the heads to the machinist to have them checked out. They were pressure tested,cleaned,and checked for flatness. They are back and are all set. The machinist inspected the gaskets and stated that the pass. side fire ring never seated. You can see that the ring is not shiny like the ring on the drivers side. I don't know or care how this happened. Incorrect torquing of the heads. Overheating. Whatever. My question is how do I know what Cometic gaskets to order for replacement. Can I measure them with a vernier for thickness? Also my engine is bored 0.030 over. Any help would be great!!
