Getting ready to lsx swap my typhoon
TrendSetter
Organ donor in training
Re: Getting ready to lsx swap my typhoon
I looked at a bunch of pictures of clearanced oil pans and decided to wing it. If it fits, then now there are sorta real measurements out there.
<3 plasma cutter
I am considering offering the cut/weld service for these swaps if there's any interest... also assuming mine actually fits :rotf:
TrendSetter
wow almost 8 grand for that?
That guy is in a pretty awkward spot in the project. it runs and drives and he as a lot of money tied into parts, but pretty much everything that makes it a typhoon is missing. its a NA motor and all the FWD stuff is not even in the truck. it also only sorta drives considering the tv cable is missing/broken/whatever. I always thought that would burn up a 700r4 pretty quick.
Hopefully it gets finished and not completely abandoned.
sparkwire
here's my experiments with oil pans tis is the first pan I did in 2002, I could not find a used pan, had to buy a new one! I cut and fit all pieces and shipped to street and performance for tig welding, they were the only ones who used a jig and would guarantee no warping. only held 4.5 qts. was put in a 1991 s10 4x4 short bed.
sparkwire
POS turbo time aluminum oil pan, came with -8an fittings(too small) had to cut corner off to clear diff. fittings would not clear diff, replaced with -10an. custom oil pick up would hit on oil pan( had a double roller timing chain that set oil pump out more in the front making it hit on the pan) pan leaked everywhere, had to put it on the mill and could not get it true. ( too much welding caused warping)
Awdlsx
Id be interested in a oil pan and mounts if you want to fab some extras up when you do yours. Let me know!
TrendSetter
ive been out of town for work for pretty much the last 3 months. i am heading home tomorrow so hopefully i can pick back up on the project in another week or so.
Justoyz1
Typhoon #849
Well, I started mine finally :D I am transplanting a 5.3 w/73k miles...removed the front clip, motor and transmission.
Received the following parts:
-transfer case adapter
-RPM solid engine mounts
-Meldon oil pan
-Stedman headers
-Painless harness
Ordered the following parts:
-ABS Delete (HTP)
-Radiator (Summit -CRI-1-25271-X)
-Dorman Fans (RB620005)
-160 degree thermostat
-cable TB (looking for used or purchase one from Summit)
Is there anything else you guys can think of that I may have missed?
Norm
Is there anything else you guys can think of that I may have missed?[/QUOTE]
front and read shafts,
what transmission are you using? 80e? might need a shifter cable and bracket, shorten the shifter shaft on the transmission, stock rad actually works well, for throttle cable, Lokar makes one , but have heard that a stock s-10 one works also from a 2002 ish model.
TrendSetter
on my s10 i used a stock throttle cable from a v6 truck with a 5.3 truck manifold and tb. the hardest part was sourcing the correct cable bracket.
TrendSetter
well im finally back in the game and making some progress.
made some motor mounts, the motor ended up like an inch offset toward the pass side. whatever.
I chopped them down a lot (weight) before paint. ill snap some photos of them some day.
heres the two most expensive pieces so far. i went for the mag adapter. im a retard for saving weight.
heres my trans crossmember i threw together. uses stock mount holes.
Norm
Nice to see you're working on it. Brings back memories from doing my swap.
TrendSetter
i really shouldnt have started it until now, i kinda jumped the gun right before a really busy time with work travel. hopefully progress is faster from here
TrendSetter
I made a little bit of progress lately, been pretty busy with other stuff.
fbody length accessories;
turbos came in. theyre pretty small
Heres about where im thinking about putting the driver side one
started the pass side, ended up messing some stuff up and need to order more material before i can progress, so i moved to driver side
driver side so far, it looks like its gonna clear the steering column ok so i wont need a two piece one like the s10
Down pipes should be fun. AC on one side steering shaft on the other. Looks like you have the skills though. Nice work.
Old Chinese proverb. Any work done to a SyTY takes twice as long and costs twice as much as planed.:rotf:
