SALE PENDING!!!!!!
I am selling my 1991 GMC Syclone - Truck has only 21,000 miles!!
It is a ROLLING CHASSIS ONLY!! - NO MOTOR/TRANS/TRANSFER CASE!!
Truck is 100% Rust Free - MINT CONDITION - with TITLE!!
First $7,800.00 takes it home - PLEASE READ THE FULL LISTING!!
I've sunk a TON of cash into this thing!! It is LOADED with options!!
The ORIGINAL Interior / Wiring Harness / Windshield / Engine Harness / Front & Rear Driveshafts are also included with the truck.
There are no miles on the suspension or cage.
Engine Bay Includes:
• Motor Plate for V6 Engine
• Manual Steering Box
• Manual Steering Shaft
• New Pitman Arm
• New Idler Arm
• Re-Supported Front Dif for Dry Sump Clearance
• STEFS V6 Dry Sump Pan
• PETERSONS Dry Sump Pump
Front Suspension Includes:
• BAER Disc Brakes
• RPM Coilover Conversion
• MICKEY THOMPSON Drag Radials 255/50/16
• Factory Wheels with Center Caps
Rear Suspension Includes:
• CALTRAC Bars
• Fiber Glass Leaf Springs
• RANCHO Adjustable Shocks
• WILLWOOD Disk Brakes with E-Brake
• Stainless Steel Brake Lines
• MOSER 12 Bolt Rear
o Powder Coated Housing
o 3:42 Gears with TRUE TRAC Locker
o 33 Spline Axles with Wheel Studs
o MOSER Support Diff Cover
• MICKEY THOMPSON Drag Radials 255/50/15
Interior Includes:
• HELL BENT Race Cars 8.50 Cage
o All Moly Tubing
o Goes THROUGH the Dash – NOT Around it!!
• KIRKY SEATS Mounted on Fractory Sliders
• LEXAN Rear Window – Roll Cage Passes THROUGH the Window – No Cuts in the Lexan!
• Cage has Extra Bars for Safety and is COMPLETELY Tig Welded.
Bed Includes:
• FLAMING RIVER Battery Shut off
• MOROSO Battery Box
• RPM Water Cooled Tranny Cooler
• BARRY GRANT Fuel Coolers in an Ice Chest
• TWO – 10 Gallon Fuel Cells
• A1000 AEROMOTIVE Fuel Pump
• AEROMOTIVE Fuel Filter
• MEIZERE Water Pump
• Everything is Plumbed to the Bulk Head with Fittings in the Bed.
This truck is MINT and will be a STEAL for the $$$$$!!
• New Pitman Arm
• New Idler Arm
• BAER Disc Brakes
• CALTRAC Bars
Interior Includes:
o All Moly Tubing
Bed Includes:
