F.S. 8.50 Syclone Roller
washclone
SALE PENDING!!!!!!
I am selling my 1991 GMC Syclone - Truck has only 21,000 miles!!
It is a ROLLING CHASSIS ONLY!! - NO MOTOR/TRANS/TRANSFER CASE!!
Truck is 100% Rust Free - MINT CONDITION - with TITLE!!
First $7,800.00 takes it home - PLEASE READ THE FULL LISTING!!
I've sunk a TON of cash into this thing!! It is LOADED with options!!
The ORIGINAL Interior / Wiring Harness / Windshield / Engine Harness / Front & Rear Driveshafts are also included with the truck.
There are no miles on the suspension or cage.
Engine Bay Includes:
• Motor Plate for V6 Engine
• Manual Steering Box
• Manual Steering Shaft
• New Pitman Arm
• New Idler Arm
• Re-Supported Front Dif for Dry Sump Clearance
• STEFS V6 Dry Sump Pan
• PETERSONS Dry Sump Pump
Front Suspension Includes:
• BAER Disc Brakes
• RPM Coilover Conversion
• MICKEY THOMPSON Drag Radials 255/50/16
• Factory Wheels with Center Caps
Rear Suspension Includes:
• CALTRAC Bars
• Fiber Glass Leaf Springs
• RANCHO Adjustable Shocks
• WILLWOOD Disk Brakes with E-Brake
• Stainless Steel Brake Lines
• MOSER 12 Bolt Rear
o Powder Coated Housing
o 3:42 Gears with TRUE TRAC Locker
o 33 Spline Axles with Wheel Studs
o MOSER Support Diff Cover
• MICKEY THOMPSON Drag Radials 255/50/15
Interior Includes:
• HELL BENT Race Cars 8.50 Cage
o All Moly Tubing
o Goes THROUGH the Dash – NOT Around it!!
• KIRKY SEATS Mounted on Fractory Sliders
• LEXAN Rear Window – Roll Cage Passes THROUGH the Window – No Cuts in the Lexan!
• Cage has Extra Bars for Safety and is COMPLETELY Tig Welded.
Bed Includes:
• FLAMING RIVER Battery Shut off
• MOROSO Battery Box
• RPM Water Cooled Tranny Cooler
• BARRY GRANT Fuel Coolers in an Ice Chest
• TWO – 10 Gallon Fuel Cells
• A1000 AEROMOTIVE Fuel Pump
• AEROMOTIVE Fuel Filter
• MEIZERE Water Pump
• Everything is Plumbed to the Bulk Head with Fittings in the Bed.
This truck is MINT and will be a STEAL for the $$$$$!!
sparkwire
Re: F.S. 8.50 Syclone Roller
Glad to see you sold this, It's been in the back of my mind scince I got your email.
Do you have any information on those baer brakes? I have that kit on my truck (came with it) and my rotors are shot, I want to replace them... and I have no idea what size pads to buy. If you know any kind of part number or something it'd be greatly appreciated. I'm assuming that it requires specific parts, if it were up to me id rip this stupid kit off and put f-body brakes on it or something what a p.i.t.a. :squint:
washclone
I can measure them if you want. I'm sure if you contact bear they would give you part number. I have a billet bracket and rotor hat to put wilwood on front. Then you can put 15 on front.
A measurement would be a good help, i'll take a poke around the baer site again and see if I find any info. Thanks for the quick response.
Nevermind, I think these are them I got lucky :tup: http://www.summitracing.com/parts/BHI-05550-020/
