Re: Engine flatlines/jumps
alright, let me lay down todays activities.
the truck has been "ECM relay hotwired modded" for a couple days, and two 5 minute drives. i'm getting no voltage improvement at idle (13.5v), and a half volt improvement at WOT (13.2v).
Went to the gas station today ran fine, went to restart the truck and it started rough. The ECM was dead. Checked the hotwire fuse, still good, checked my ECM1 and ECMB fuses, they were good. The ALDL had no output. So i limped it home on 0deg timing.
Got it home and verified the ECM is getting power. The fuel pumps run so it might not be completely dead. I jumpered the ALDL, and the "Check Engine" light did not flash at all. I reloaded my BIN to the ostrich, and it verified it accepted. But it still ran horrible, so the ECM isnt sending anything to the engine. Tried my old ECM that stop working awhile ago. It ran worse, i jumpered the ALDL and the "Check Engine" light stayed solid on the old ECM.
So to recap, i have good power everywhere, good grounds, but neither ECM will communicate with the engine.
Now i'm off to buy yet another ECM, without knowing what killed this one.
any ideas?
