Sean Krupa
Moderator
Rob(Wyosyclone) has been helping me since I got Code59. We have tried numerous Bins in my truck, but the Starter Bin that I got from Hood is working the best. The boost was set around 17.92psi from what Hood set it at. Rob told me to lower the boost in the F71_MPH table to 55 + F70_MPH to 14.99. Once I did that, the boost was lower and much safer to do a DM run. Now here's the problem. After I lowered the Boost, we went to do a DM run. The KR is very low to non-existent which is great.(1st pic)
Rob suggested that since my Wideband is PLX, that I changed the Setting in the Flags section to the PLX instead of the Techedge. He said it might change my AFR values. Besides the PLX change, I lowered the F71_MPH to around 53 at around 50mph. The KR is a lot higher for some reason in this run.
Since that run was worse, I decided to switch back the WB setting to Techedge to see if it would help and it didn't.
The only thing that I think would make a difference is that the 1st run was taken in the evening about 10-15* cooler and the 2nd + 3rd runs looked Leaner. I tried PMing Jeff, Hood and Dig since Rob is on vacation till tomorrow, but they didn't reply.
Any help would be appreciated. I felt that I was almost done with my Tune, but now I'm still fighting this KR issue.
