Code59 Bin Help
Sean Krupa
Moderator
Re: Code59 Bin Help
Heres a new File with the Timing reduced a little in mid-upper range and a bit more fuel. Was kinda shocked on the run. No KR throughout the whole run. I told my dad to go WOT and he thought I said Knock and let off a bit, that's why you see the dip in TPS. Rob has another Bin that he wants me to try with the F70 table adjusted a bit. I will post that one soon.
turbodig
Re: Code59 Bin Help
Might need to bump some fuel pressure... you may be getting to a point where you can't deliver any more fuel with the injectors you have, try another 5 psi.
Sean Krupa
Moderator
Re: Code59 Bin Help
Well I already have the FP at 52psi. The AFR doesn't go over 12.1 in the run. Like you said before, maybe this is what the motor likes. It's not really showing a sign of KR because of it being lean on this run.
Thanks,
Sean Krupa
Moderator
Re: Code59 Bin Help
- Dig, Did you want me to add the 5psi to my current 52psi FP?
- Being that these runs were in 90*+ humid weather, do I need another Bin for a cooler day, like when I go to the track? Will the tune change a good amount with weather?
Sean Krupa
Moderator
Re: Code59 Bin Help
Heres the latest Bin that Rob sent me. It was the same Bin as above, just an attempt to lower the Boost on the Top end. We eased on the throttle in the beginning because I didn't want the fuel to go to the back of the tank. I only had 1/2 tank. I believe that is why I had some KR because of it being part throttle. Other than that, it looks very solid.
Do you guys think this Tune is safe enough to take to the Track? I would really like to find out what it runs being that I have a mostly stock Ty with the Mods listed below. Would adding some Torco Accelerator or Race gas have any benefits of being safer at the Track? My dad will be Towing me on a Trailer.
Sean Krupa
Moderator
Re: Code59 Bin Help
Here's an update. I installed the Racetronix FP Harness. It definetely made a difference. The AFR is a lot safer now. I was pretty shocked on how much of a difference there was. I actually saw the AFRs in the 10s. My dad and I are almost done with the Alky install so I will post a Bin of that hopefully soon.
Sean Krupa
Moderator
Re: Code59 Bin Help
Here's the latest DM file with the Alky installed. I'm shooting for 20psi with pretty good Timing.
