Clink Clink noise from front
TYPHOOL7
Post Hawk
okay i just changed the axles on my ty, and began to notice a noise. clink click which increases when i go faster i am unsure what is exactly causing this. any help would be great. :eek: :eek: :eek: :eek: :eek: :eek: :eek: :evil:
ParTyBoy
Re: Clink Clink noise from front
check the fluid level and consitency in your front differential.... any shavings? is there a resonating pitch that changes or becomes more profound as you accelerate?? a higher pitch at higher rpms?
also check and make sure your wheels are torqued down properly... If they aren't... it can cause the wheel to make a clunk sound.. or cause one or more of the wheel studs to break off....
TYPHOOL7
Post Hawk
That seems to be my problem, shavings what do i do if so? wheels are properly secured, i will check my fluid asap :wink:
also what kind of loot am i throwing away when i have to get a new diff? :eek:
nomoty
Still Boosted
well it depends if you can rebuild it yourself really cheap or buy one from a junkyard or another SYTY owner or off a 4x4 s-10, s-10 blazer, t-15 jimmy, 4x4 sonaoma or a diff off a bravada (only if you change the 3.73 gears back to 3.42's) If you need a new tube shaft then you can get one off the right hand side of any the listed above and replace the one on your left side. If you buy one a shop will most likely charge you around $300-$400 for labor alone to install.
TYPHOOL7
Post Hawk
OUCH! THATS BAD NEWS SINCE I CANT RE BUILD IT MY DAYAM SELF :lol: BUT I AM GOING TO LOOK IN THE MORNING SO I WILL KEEP YOU ALL INFORMED OF THE PROBLEM, THANKS :wink:
TYPHOOL7
Post Hawk
NOOOOO, MY DIff IS DEAD, that sux, i am going to post a new topic in classifieds for a diff, anyone?
Ian Turgeon
Cascading Inspiration
Look into the cost of doing it yourself. If its enough of a diff try it yourself. If you f it up, theres only so much damage you can do.
Get someone's help. Get some phone numbers. Theres enough knowlegable people willing to share out there.
Its all about time constraints and funding after that.
(wish i was at the position where I could pay people to do shit instead of having to bust my knuckles or watch the ABS light for 3 months)
