TYPHOOL7 said:okay i just changed the axles on my ty, and began to notice a noise. clink click which increases when i go faster i am unsure what is exactly causing this. any help would be great.![]()
:evil:
That seems to be my problem, shavings what do i do if so? wheels are properly secured, i will check my fluid asap :wink:check the fluid level and consitency in your front differential.... any shavings? is there a resonating pitch that changes or becomes more profound as you accelerate?? a higher pitch at higher rpms?
also check and make sure your wheels are torqued down properly
