Re: Can I use them like this if they fit ?
MRKING said:
I think the length of the coil determines ride hight . You could go with a higher rating on the coil to raise the vehicle but the ride would suffer . Going to a lower rating to lower the vehicle would make the front end feel real spongy .
My friends sy is more slammed then I want mine set up , and I believe his rpm setup is 9" coils . Thats the only reason why I have been searching for 10" coils .
There are a couple of variables with springs that would affect ride height.
1.) Rate. This is the difference in force between 2 positions, in lbs per inch (since we're working in US units) for a coil spring. Torsion springs are going to be in different units. For two springs that are idential in free length, but different rates, the ride height will change, because the amount of load hasn't changed, just the deflection.
2.) Free Length or position is an important consideration. If you take 2 springs with the same rate, one that's 10" long and one that's 6" long, the shorter spring will put the truck significantly lower (might be 4" or 6" or 8" depending upon the front geometry).
3.) Geometry.
The stock torsion bars are working through a pretty small lever arm, look at the distance between the a-arm pivot and the torsion bar mount, it's like what 3" or so? The torsion bar has got to be really stiff in order to hold the truck up with that kind of mechanical disadvantage.
If we compare the coilover setup, its got a much better mechanical advantage, since its acting 2/3's of the way down the a-arm. But, its mechanical advantage is compromised by the fact that the shock is mounted at an angle, reducing its effectiveness (some of the spring rate goes into trying to pull the a-arm out of the truck horizontally, instead of holding the truck up).
I'm interested in this swap. Keep all of us posted as to what you find.
'JustDreamin'
