MIGHTYMOUSE
Turbo F body guy
i fought the engine drop in all day and this is what i have to show for it
some facts
turbotime ls1 frame mounts
turbotime ls1 pan
4l80e conversion
1. how in the world should i go about getting -10 fittings in here? The one on top of the diff will not be possible, so what is the solution?
2. i ground the ridge off of the trans and the firewall looking for roon any way i could make it. anyone else done a 4l80 and ls1 swap? turns out the grinding was a waste as the rest of the trans hits the tunnel at this point
3. how am i supposed to make this work? see how much lower the hole in the mount is? I can't put the engine any higher because the trans hits the tunnel. The drivers side is worse
4. i dont know how much this is impacting the install but there is contact in this area, i cannot grind the pan because it is a welded seam i would be breaking through
please dont let it just sit like this after all the investment
some facts
turbotime ls1 pan
4l80e conversion
