Beavis
Still plays with trucks
Re: Black Water Necks
Is this a track only truck or highway driver? If you use a small hose like that then you may not want a thermostat. There is a washer systm that will slow down the flow of the water, but to slow and won't cool it off the engine enough, too fast and the water won't cool down enough in the radiator. There is a fine line between the 2. :2cents:
another option i'm considering is an AN fitting neck:
from what little research i've done, they come in -16 and -20. Obviously this is a tad thinner than our gaping hole stocker line...is there goign to be any adverse affects from running a thinner diameter line? Whats the recommended size?
