Re: best turbo upgrade with stock everything
The Waller turbo is using your stock turbo & modifying it.
Send him your turbo or possibly purchase a core from him.
He would machine the compressor housing to fit a 57 MM compressor wheel, the one step further, would be to machine a stock turbine housing to install a larger better breathing "H" turbine wheel.
http://www.ebay.com/itm/Kinugawa-Tu...Parts_Accessories&hash=item232e599d95&vxp=mtr
So in short, you can retain your RPM C.A.I. & charge tube w/your B.O.V.
Here is a pic of my 10CM turbine housing machined to fit a larger "H" turbine wheel. You can do the same to your stock 8CM turbine housing.
Here is a stock compressor housing.
Here is a stock compressor housing modified by having a 3" billet inlet made & welded to the housing & then machined to fit a larger 60-1 compressor wheel.
Modified left, stock right
