Re: Aluminum Bowtie vs Stock block
Bowtie should be bowtie. Billet crank, bowtie block, billet rods, aluminum heads.
Stock block should have a stock crank (nitrided, splayed caps etc)
I would not suggest a $3000 billet crank in a $250 block, or putting a $575 crank in a $3000 bowtie block.
We have had numerous trucks dyno 575ish RWHp so around 700hp with stock components (block/crank). It will last if you dont race it 100% every weekend. 90% of the time on 15-17psi making 500-550 at the crank. Is it bulletproof no? Will it last forever no? Campbell will tell you the same thing.
Everything is relevant.
Scott buddy wake up. You missed out on a complete ready to run fully balanced rotating assembly because you couldn't afford a 50% deposit, now you are spending thousands more to wait longer and listen to people blow smoke up your skirt...
