Alignment specs
bizkit
bonofied SyTy junkie
Re: Alignment specs
4C FED said:
I wasn't happy with the inner tire wear using the modified specs.
I also used the modified specs for my last alignment and noticed inner tire wear. I'm not too happy about it either..... Getting it changed back to stock specs.
Re: Alignment specs
Inner tire wear will be caused by too much negative camber, or too much toe in or both.
Re: Alignment specs
TwinTurboV8Ty said:
, or too much toe in.
Didn't you mean toe out? Aside from camber, if the tires are wearing the inside I would think toe out which, depending on how much, will make the vech very difficult to drive. Wants to wander something fierce. If you've never driven a car with toe out you don't don't know what yur missin'.
bizkit
Re: Alignment specs
Turns out my problem was the cam bolts. Those two washers on each bolt are ribbed on one side to grip the frame bracket and the ribs were wore off just enough so the bolts would turn and kill my alignment. New bolts/washers/polyurethane bushings and the upgraded alignment specs have me driving with a smile :tup:
ndburli
Re: Alignment specs
So bringing back this old thread...I am getting an alignment this week. Should I go with factory specs or the "upgraded" sportmachine specs? Anyone has one or both of these setups and how about the tire wear? Thanks
mattw
Re: Alignment specs
I've had great luck with and would recommend these specs:
Caster +6
Camber -1/4
Toe in 1/8"
They were provided by Jeff Scott..
ndburli
Re: Alignment specs
Last call for opinions...I am leaning towards the modified specs but definitely worried about inner tire wear from previous posts. Any last opinions on which one to go with?
atkonkler
Is this your bush?
Re: Alignment specs
Find an old-school alignment guy that does it without the use of this fancy machines that don't have the specs for our trucks ! They do it with tape measurements and and levels and plates! I did it with mine and man was I happy ! Just do some searching and you will see the difference
mattw
Re: Alignment specs
I have a set of specs I've used for all "wide tire" street cars since I bought my Corvette in 1985. My biggest concern for choosing a spec is tire wear. Performance tires are expensive. The GS/C's for my 88 were $250 each in 1995. What's interesting is that my specs are right in the middle of the factory-recommended specs for the Typhoon. I've never looked up the factory Ty spec before. But they work for me for minimum tire wear on a street truck. The factory spec is almost identical.
Jeff and I are friends. We've discussed his recommendations. He prefers a lot of Caster. 6-7 degrees. This will make it track at speed like it's on rails, but isn't much fun to drive. Big positive caster increases steering effort, because the geometry "lifts" the weight of the car as the wheels are turned, and this is felt in the steering wheel. At parking speeds, you can see the hood lift as you turn the wheel.
I complained about on-center wander in my Corvette when it was new. The guy put 8º of Caster in it. It was way too much. No fun to drive. I got it home and removed enough shims to make it a guesstimated 4º Caster. I've never had it on an alignment rack since, but the heavy steering went away.
My experience has been that any negative Camber will result in inside edge wear in normal street use. The EXCEPTION is if the car is tracked, auto-x'd or driven in canyons regularly. If so, a few tenths of negative will minimize outside edge wear if it is excessive when driven regularly at the limit.
0º Camber (exactly 0 for both sides).
+3º - +4º Caster (try to hold within .5-.75 between the sides, but this isn't as critical as Camber being 0.)
.1-.2 +/- .05 deg toe-in per wheel. (Just a tad of toe-in. don't need much at all with good steering components).
Dave, thanks for that explanation. I'll be sure to keep a very close eye on inside tire wear. Does your Vette have manual steering? I have both of my vehicles set to 6 degrees of caster and I don't notice the wheel being hard to turn at all.. They do track perfectly straight down the highway which I love.. If I do notice tire wear on the inside I think I will try:
0 Camber
5-6 Caster
1/8" or less of toe in
Re: Alignment specs
I have my black ty set for 0 Camber and notice outside tire wear (granted when I do drive it its driven hard).
I think 1/4 Negative is going to be my new trial.
I recently helped Paul put coilovers on his ty and we got almost 7+ deg of caster and he loves it, at least in a syty I don't notice the hard to turn effort. Corvette I can see it.
Dave is just old and grumpy also.
Re: Alignment specs
:2cents: Personally caster is a good thing. Always such a thing as to much but my old 325 Bimmer had lots and it wasn't hard to hold in a curve. Also when in the turn caster gives you negative camber on the outside wheel, positive on the inside. Which, to a point is useful. (Just look a a BMW or Mercedes with the steering at or close to full lock and you'll see what I mean. These cars tend to have lots of caster.) With our rudimentary suspension there's a lot of compromise anyway.:2cents:
TNPhoon
1of28
Re: Alignment specs
BUMPITY BUMP BUMP BUMP.
Don, what did you wind up going with?
I am the same setup - stock wheels, stock height, 30psi tire pressure.
Don't want to eat up the tires prematurely.
Stock specs? Modded specs? What did you guys choose and how's it working out for you? Every thread that I found about alignment were pretty much left "open" and no follow ups on how the specs worked out.
Thanks in advance!
sychris
Re: Alignment specs
my truck was wobbling like that at like 70 .put new pittman arm / idler arm and no more wobbles
Re: Alignment specs
I've running the "modified" specs for quite some time 3 years? No issues. Truck drives clean with no pull, easy to hold in a turn. (We have power steering, how hard can it get?)
BMFB
Not to scale
Re: Alignment specs
Just what I've been doing...
I decided to scrap everything i've seen on here for allignment specs. I looked to the autox evo guys who have been playing around and took alot of what they have been doing, toned it down a bit, and applied to the HSB.
Caster - +6.5*
camber - 1.5*
Toe - 0
For driving around its great, I run 275's on this around town, wrinkle wall slicks at the strip (and sometimes around town) as well as R1 track slicks for autox and such. This same alignment seems to work great for all of it. The truck does not track around or drive stupid, even on bad roads. I am running a newer pitman arm on a Zq8 steering box, but everything else has alot of miles on them.
Only thing I can say is when I get on it from a roll with the antilag the truck with track for a split second in to a random direction, but It could be torque steer. This is a 135mph truck in the 1/4.
Damian
Re: Alignment specs
Anyone know what the wheel track measurements are? Gonna start doing my own alignments and I cant find the specs anywhere. Found them for my Durango easily.
Gonna test out the Sportmachines modified specs.
Re: Alignment specs
Running zero toe on an older truck like these (box, idler, pitman,etc.) doesn't make much sense. A small amount of toe will help it track straight and reduce the "constant steering input". On lifted trucks - like my S10 - I always add a little more toe to compensate for the larger tires/sidewalls.
If you launch a lot or care about drag racing, I'll typically run the camber slightly positive - within spec or slightly more - due to the usualy negative camber the front wheels see when they unload. It tends to keep the tire slighly more in contact.
That all said, even on a modern high tech Hunter machine I'll struggle to even get a S/T truck within spec; things just weren't as precise as they are today.
blue83z
Re: Alignment specs
Bumping this since I had the Ty aligned this morning. Tech saw the ticket and asked the service manager for the alignment.
Guy in his 20's, his dad had a typhoon back in the 90's. He remembered a boost launch when he was a kid.
Anyways, we got camber cranked up as far as possible, but it's well short of the modded specs for sure.
I would imagine there is a cam kit to get more caster? Anyone have the part number handy?
Re: Alignment specs
Hopefully your camber isn't jacked up too much, as that will wear tires. What caster did you finally end up with?
There is no "KIT", there is a limit of course though.
blue83z
Re: Alignment specs
I had them set camber slightly more negative from factory specs, but not as far as the Sportmachines "modded" specs. I don't drive hard enough to go that far negative.
Caster ended up at 1.5 and 1.2. Way less than what I wanted for sure, and slightly more positive than it was, but nowhere near the 3.0 I was hoping for. Guy said he thought there was a cam kit with a bigger offset.
