97 Sonoma SYTY Conversion
mmp142965
say it like you spell it!
Re: 97 Sonoma SYTY Conversion
There's pics somewhere on the BB or the internet of a green S-10 with a similar intercooler and the scoop mike is talking about. I couldn't find them though. maybe someone knows where they are?
DonHo32
dgoodhue said:
I don't have any first hand expereice with blow by and how the plugs look.
Look at #2 of the buyers guide.
http://www.syty.org/old/buyers.html
Thanks for the info. This blow by described in the guide is exactly what i am seeing. This engine has fresh rebuild plugs and papers for when it was rebuilt. I just can't believe that this is happening. I think i am going to tear it down and do what i had originally planned to do from the beginning. Assuming that i am starting over what would you suggest for the bottom half?
DonHo32
QUICK STORM said:
got any more pics of the truck?
Not yet we had to delay the clean up due to engine problems. i am getting too much blow by. we started taking the truck back apart again last night. The whole front end is disassembled and the motor comes back out today. I am going to rebuild the entire engine and swap heads like i should have done in the beginning. I am going to build this thing right and i don't care what it takes I just want it right. Depending on the condition of the internals i may need some advice as to what pistons, rods, cam, etc to use. And if you have a link to a "How to convert the Vortec Heads" that would be great.
Sy-Clone
Boost Junkie
DonHo32 said:
Verrrry nice man. Let me know how it turns out.
Our projects have alot in common. I' ve worked by myself on mine. You're fortunate to have at your disposal expert help. Imports are the thing here where I live. Puerto Rico is well known for it's rotary powered cars. Hope we can share info in the future.
PEACE>Tony
DonHo32
PEACE>Tony
PM Sent
DonHo32
I have started tearing down the motor and its looks like its gonna take about 2 weeks to complete the rebuild and re-installation. While it is apart is there any suggestions on the stock turbo? What can be done to enhance its performance? I had planned to upgrade to a larger turbo but with the cost of the rebuild i think i will stick with the stock unit. Any help would be appreciated. Thanks
DonHo32
Update: Got into the motor last night and sure enough 2 rings were cracked which was cause of the blow by. Everything is in pieces now. I will be updating with more build pics soon and i will give a list of the mods at that time as well. Special thanks to Waller for all of his help.
DonHo32
Got all the parts in and starting to put things back in place. Hopefully we will have the truck together and on the road within the next week or so. We have been taking a lot of pictures of the build and i will send them to Quick Storm for him to post, but here is the list of items that make up the build (some were installed on the first build):
93' Typhoon 4.3L Motor bore 30over
SRP Forged Pistons
422 Comp Cam
50# Injectors
Vortec Heads (Waller)
Walbro 255 Fuel Pump
Billet Fuel Regulator
Manual Boost Controller
Alky Injection
TCI 2600 Stall
Custom 3" Down Pipe
Stock Turbo
MagnaFlow 3" Exhaust
Vortec PCM (Reconfigured)
Vortec Ignition
Dual Flex-Lite Electric Fans
Air 2 Air Intercooler
Tranny Cooler
3.42 Gears
No Cat
160 TStat
Auto Meter Twin A Pillar Gauges (Boost & Trans Temp)
Caltracks
Do you think the 97 ECM and knock you experienced connect to this problem?
If I were to bet on what caused it, this would be my first place to look.
the 97 just isn't setup to read boost. Yes it can be fooled somewhat and get to run but....
DonHo32
We have done a lot to correct this issue. My only hope is that what we have done will solve the problem. If not, I really have pissed away a ton of $$$$. Worst case scenario I will go to the stock SY ECM, but I really think the 97 can work.
Just be cautious ANY knock on syty engine can be bad. If you can hear it, it is REALLY bad.
DonHo32
Thanks I really appreciate your input. I know you guys really have gone through every issue imaginable with these trucks and any advice given is truly taken to heart. Waller has been extremely helpful as many others. Anything that you feel would help to prevent the knock is appreciated. I really want to try to keep the 97 ECM, but if is not possible then I will change it out.
This project has set my secondary dream back a while which was to actually own a Syclone, but I will get one. I also realize that my project is not necessarily the most popular one on this Board, but as you can see I actually have done what I said I was going to do. And now I must say that the majority of the members have started to warm up a bit to it and are interested in its progress. Thanks everyone and I will have some great build pics up soon (STORM wherUb :) ).
