AlhozamiAutoAli
hey guys i have started this project a few days ago... and looking to have a powerful and light awd car ...
im planning to start by just using rear wheel drive to save time and install the front drive shaft after all the bugs have been fixed and untill the car would be stable because the previous owner told me about the ls1 oil pan conflicts with the front driveshaft system.. when all is going right and the car is set up.. i will begin the phase of staged upgrading starting by modding the oil pan and installing the front drivetrain after..
i plan of using a thm700r4 transmission and i will also already install the transfer case.. and in the future hoping to upgrade to a ratchet shifter system
the car has a 5cm body lift installed as a result for the oil pan to fit:search: .. but seemed unsuccesful so i would also remove that
im new to mechanics and im 14 so i need you guys to guide me through here's my list of works to do
1=change wheels for easy transport and to look decent
2=remove the whole front driveshaft
3=remove the whole front body panels for easy engine installation
4=remove the 5cm body lift installed
5=clean up the whole engine bay
6=mount on the engine and transmission
7=install engine components
8=install harnesses and electrical components
9=restore all handling parts like brakes and the suspension system
10=test drive the vehicle
11=fix any remaining bugs
12=restore body parts
and after everything is done and if i found a solution to the oil pan palroblem
i will go forward to installing the front driveshaft and run awd.
anyways please give any comment or suggestion that would help me with this project thanks..
i leave you with some pictures i took for the car:cheers:
