don't know how to describe my problem, but i'll try my hardest so that you guys might be able to help me out.
driving along and accelerating around 60-65 mph and it seems like power goes limp unless i keep accelerating, either hard or continuously past 65 mph and the fuel pressure goes to 43 lbs. the best way i can describe it is >it's like when driving a stick shift and you down shift into the wrong gear and you stay in that gear until you get back up to speed. (if that description even helps?)
normal driving i've got 38-39 lbs. fuel pressure. if i accelerate hard then it goes to 40-43 lbs. fuel pressure.
~afpr "T"d into map vacuum line
~no cat. converter
~no knock
~no check engine light
~running at 18 lbs. of boost (only in WOT)
~only use chevron 93
just listing things that might help you guys to figure stuff out
~no cat. converter
~no knock
