2010 Camaro Wheels
scrape
Re: 2010 Camaro Wheels
on the subject of 2010 camaro wheels. how do any of you think these would look on a SGT. they look like a modern version of the stock wheel in 18". seen these on few base model camaros and someone has a set with tires on local CL for $500.
13Pelle
I think they have the potential to look good on a GT. I was looking at them as a beater set for while I was refinishing my stockers. I have seen a few sets here local to me for cheap also. IIRC less the $500 for the four....
BoostedSUV
My Girlfriend works for SLP and I can get new Camaro take off wheels for next to nothing. I still wouldn't put them on my truck, they look way to big for my taste.
keith455
Average Joe
Staff member
I'd like some Hurst Camaro rims if anyone knows where i can get them cheap.
Injected1
That's just so crazy that I had to post it. $691 front $708 rear!!!! What were they thinking?
13.robb
I want to put the same wheels on my Typhoon w/ 255 35 20 all the way around but i'm not evan sure if the bolt pattern is the same because the ss wheel is 5-120 and the ty is 5-475 I plan on bagging the truck w/ racing shocks I will tub the front and back so this will work i'm just not sure the wheels will fit on a 2" lowered ty in the 1st place or evan if they'.ll work after the truck is done.
Just wondering if anyone has any more info on this 5-120 vs 5-4.75?? With a micrometer the difference is very minimal @ about 1/16". I picked up the 19x8.5 versions of these. From the looks of it i will need to have the wheel centers bored.
13.robb
Thanks for the info. Ill be running a 275/35r19. Hoping not to rub. should be ok by the measurements...barely.
JAY
Old post revisited BUT I scored a complete set of Camaro 20s with tires. I'll post some pics after I figure out what spacers to use.
Injected1
Exactly what I was going to say!!! Only need a 10mm for the rear. Post pics once installed. Mine is on hold for a while.
SEL777
One of 101
IMO the wheels wells on our truck.....are well truck wells,and would nonrmally run much taller tires. I think my ZR1 wheels look too small for the size of the wells. If you can use 'em w/o damaging the cladding...go for it. I would have to have a minimum rear size of my current 315 though...they need to be wider from the factory. What's the price on the 20" tires you plan to run?
