2010 Camaro Wheels
QWERTYphoon
Motley Driver Award 2009
Re: 2010 Camaro Wheels
We have a couple board members who are still waiting for things promised months ago by Injected1...
Neither member has recieved the promised goods from Injected1......
I guess to the dog house he goes.....
Injected1
Talk to Crazykaese before you run your effing mouth anymore. Your a real @$$hole and you need to back the F@#^ OFF!!
QWERTYphoon
It takes a big man to admit when they are wrong. I am not a big man. Just talked to Dennis, says he has not recieved anything, but he will check his mail when he gets home.
Injected1
OK.....I think I have come up with a plan. I am going to move the rear Camaro wheels to the front and have the front 8" wheels widened to 10.8"
As for tires I plan to run 4 285/30/20 Michelin Pilot Sport PS2 that have a diameter of 26.9
Now for my question: Has anyone ever run a tire with a diameter this large? Can I make it work with a 2" drop? Seems like a large diameter tire, maybe 2 large.
Any help would be greatly appreciated.
Injected1
Might not look right. Outside lip of the Camaro rim will stick out 19mm more than stock.
How do you get 19mm out? I did the offset calculator and it said 1mm out. Am I doing something wrong?
Injected1
Never mind I see what your saying. Guess I will have to widen all 4 instead. This could get expensive!!
RydinLowSince2000
13.84 @ 98 mph
I want to put the same wheels on my Typhoon w/ 255 35 20 all the way around but i'm not evan sure if the bolt pattern is the same because the ss wheel is 5-120 and the ty is 5-475 I plan on bagging the truck w/ racing shocks I will tub the front and back so this will work i'm just not sure the wheels will fit on a 2" lowered ty in the 1st place or evan if they'.ll work after the truck is done.
Dr.Gixxer
I have those same camaro wheels and just picked up a set of 255/35/20 so i'll see if it works.
Beavis
Still plays with trucks
5-120mm or 5 on 4.75inch. And it probably wont work too well lower 2". Might hurt the cladding. :2cents:
Chest Rockwell
it doesnt say if the truck is 4x4 or 2x4. i think that would make a difference on the front spacing on both front and rear. :2cents:
It does say further down that it's a 2wd. I had to look at the Colorado tail-lights for a while, to decide if I like 'em or not. Definitely a unique mod to the truck. That thing NEEDS BRAKES!
sharkbait
yep. your right. and yes it does look awesome. however, i think you guys (awd) cant tuck front wheels as much as a rwd S10.
