Re: 0-60 time?
If you want to work on your 0-60 time (either 60' or 60mph) You need make sure your truck running upto par via scan tool, & you need to work on your launch. You will need track time or atleast a G-tech to measure this and record progress. If you have a mostly stock truck and are getting low 1.7's 60' your doing pretty good for a luanch. One thing that help with launch is coilover front springs with their limited suspension travel. Its force the truck to launch flatter and with more front wheel traction. If your doing a lot of boost launches, get a tranny cooler, replace the front propshaft and motor mounts (or get an engine tie down)
